318 Modified
Nero
My E21(s): 83' 318 Manual Twin Dellorto 40's
318 Modified
Post by Nero »
First,
Hi to all, I'm a new member here and I apologize for my english :)
I have registered to this forum to share my experience with the e21 and to ask for tips and practices.
Two years ago, I have bought abandoned project car.
Car was rust and accident free, painted (not so good, but OK), but not running, interior stripped out etc.
Base was 315? I think, but it had a 1,8 M10 engine from an 1987 e30. It also had a poorly fitted twin dellorto 40's, 5 speed from an e30, driveshaft was too long, brakes didn't work....a lot of work.
Few pics
I had these seats form a previous car :D
First thing you do when you buy an unfinished car is....buy the wheels for it :D :D
These are 8x15 ET0
Love the look. I know that they are ''replica's'', but in my opinion they look great on the car.
When we started to work, I saw this ''solution'' for a gearbox mount:
Luckily, there are parts for bimmers, so I bought an used mount:
I had two shafts, but one was too long and other too short:
I have taken it to the local machinist, and he has shortened it for me and it fits perfectly.
After that, I have taken the car to the exhaust specialist (there was no exhaust on the car):
nic65
Re: 318 Modified
Post by nic65 »
Engine is ex 318I e30....Good
Re: 318 Modified
Welcome here! Thanks for taking the time to share your actions with us, you've already done a bunch of nice things! Perhaps there's still a lot of work to be done, but it looks very close to driveable to me now, or not? Keep us posted, and we will try to help you where possible!
Nero
Re: 318 Modified
Post by Nero »
When we tried to run the car, car was not working properly. After couple of hours of tinkering, we have found a problem. Car has a 300? degree cam fitted by previous owner, but it is for a M10 before the 79' and it spins in the wrong direction.
Solution was to find the correct distributor
I have found one, but it's an old type distributor with points.
I have updated the distributor with an electronic ignition and car run smoothly :)
After that, it was time for an suspension update. Car was fitted with an Golf mk1 coilovers, I have just changed the bushings to the strongflex:
Before:
After
Also, I have bought an front and rear 323i sway bar (23,5 mm and 16mm)
At the same time, I have done the brakes refresh
Rotors are stock, pads are EBC Yellowstuff
Also, I have noticed that previous owner has done some ''funky'' stuff, probably to fit the oversized wheels:
As I have rear 323i subframe, I have done just a quick fix
And car was on the ground.
New radiator hoses:
New radiator:
I have removed servo brake drum and fitted a pedal box with wilwood master cylinders
As I decided to move the battery to the trunk, I've bought a Motamec battery tray
Some more test rides :)
Brakes are underpowered to the spirited driving :(
One of many emulsion jets...
First ride :)
Car is fitted with an e30 gearbox, so there is no speedo pinion. I have bought and GPS speedo from aliexpress:
First test
And then, fitted it to lock ''stockish''
Tried the Alpina wheels, didn't like it
Nero
Re: 318 Modified
Post by Nero »
Bought a set of Fondmetals 7x15 ET13
New fuel pump
First service
I have also fitted an oil cooler:
Stock look for MOT :)
Back to 8x15
Random shots
Decided to put the air filters on:
nic65
Re: 318 Modified
Post by nic65 »
great job, i did a similar thing on my 316 '80
Re: 318 Modified
Some serious work done sir!!!!
Re: 318 Modified
Whow, great story, your English is pretty ik, keep it up!
Love the wheels, love what you have done to the car!. The front 8x15" wheels do hit the front wings, by the looks of it? What is the status of the interior?
Nero
Re: 318 Modified
Post by Nero »
Decided to switch from Golf coilovers to Koni's and H&R
(it was a mistake) :D
Nero
Re: 318 Modified
Post by Nero »
uwbuurman wrote: Thu Oct 21, 2021 12:47 am Whow, great story, your English is pretty ik, keep it up!
Yes, I have done the arches later (work in progress), 8'' ET0 in the front is a bit too much without fender rolling
Nero
Re: 318 Modified
Post by Nero »
First event
Just a few days before the first event...due to my driving:
I've got a first failure
As I've got a parts engine, I have used those rocker arms and fixed the car for the first event.
I'm searching for stronger rocker arms (contacted KM cams and Korman auto works but still no response), do you know where I could source them?
Also, I would like to buy a stronger sway bars, but I don't see any options in EU, do you have an idea where to find it?
And what coilover do you suggest for fast street/track use? I'm not satisfied with Koni&HR combination.
In the meantime, I have and LSD and brake upgrade on the shelf, I just need some time to do it :)
Nero
Re: 318 Modified
Post by Nero »
And also, I'm quite happy with the cars performance:
But I have a lot of issues with carbs and I'm thinking about ITB's and EFI..
Re: 318 Modified
Welcome here, love all the work you've done to the car.
It seems you know a lot about bmw's, exept the max RPM of a M10 engine LOL. I think that hurts.
Acceleration spec is impressive too
Wilmo is the M10 ITB and EFI expert here on the forum
Keep up posting here, we like it.
Nero
Re: 318 Modified
Post by Nero »
BertjeConti wrote: Thu Oct 21, 2021 8:31 pm Welcome here, love all the work you've done to the car.
Max RPM is just a number :D :D Until you lose your rocker arms :)
Is there a topic with Wilmo's build?
Re: 318 Modified
https://bmwe21.net/forum/viewtopic.php?f=19&t=16205
It’s in Dutch, but ok.
Very cool build! And it looks like we’ve faced similar challenges. I have just ended up at the topic of suspension. I’m going to make a height adjustable suspension, with Bilstein B6 dampers and different springs.
It looks like you could use electronic ignition so there is a very specific rpm limiter which you can tune.
Your acceleration is impressive. We’ve got similar engines but I have injection with ITB’s. A theoretical best 0-100 run is around the same number but in reality it was around 8s. Before I shifted quicker than I can do now :p
