Hello,
I have a US 1982 320iA 1.8l that will crank and not start.
Here's what I know:
Car has fuel, as I filled it up the night before and only drove it less than 30 miles at around 80mph.
I was able to start the car afterwards, however, just around the corner, it sputtered, and bucked a bit, then died.
I took off the gas cap to rule out vapor lock (the car will still not start after a week).
Battery is fully charged.
Fuel pump fuse is good, I even took it out and cleaned it a bit and twisted it while reinstalling it.
Fuel pump relay is good as I took it out and tested it in my 1983 320iS.
Car has plenty of spark!
No fuel spray out of the cold start valve.
I took off the fuel line to the fuel distributor off, and cranked it, and no fuel came out.
I hooked up a 12v battery directly to the fuel pump (while the connections to the car battery were still hooked up) and the fuel pump did not make a sound.
I am pretty confident that it is the fuel pump. I do have the one known fuel pump on my 320iS that I could swap to confirm, however, I do not really want to spend the time at this point.
Is my assumption correct in that it IS the fuel pump? Any guidance is greatly appreciated!!
Regards
1982 320iA cranks, but will not start....another starting issue thread!
Re: 1982 320iA cranks, but will not start....another starting issue thread!
You should defo hear the fuel pump so my money is on that one too
