need help with swaybar washer order.including rubber plated washer
Letmein
My E21(s): 1981 320i
Post by Letmein »
doing new front end work. have the 2 rubber plated washers and metal washers. i need a good diagram or list of how they install. i dont see what the rubber goes against. i think realoem is not correct on this diagram becouse the mount for my swaybar at the control arm(wishbone) is facing opposite direction. therefore if rubber washer went against the metal spacer side of the mount on control arm iit wouldnt make sense. the rubber on washer isnt even touching anything. anyway hope someone can help.thanks. so to be clear i need the order and which way the rubber washer faces.
Re: need help with swaybar washer order.including rubber plated washer
Like this imo, one set of bushings around the trailing arm, a spacer, then a set of bushings around the sway bar.
