I’ve been searching high and low for 323 rear break dust Sheilds but can’t find any
Has anyone tried modifying another shield like a e30 or something similar
Or is there another option that can be made to fit?
Any advise on this will be much appreciated
Modifying break dust shields
Re: Modifying break dust shields
Dont think that e30s will work. But you can try and source a used e30 dustplate to compare? If it is doable, than order two new ones.
Rear brake shoes and discs are the same as e30 so there is some chance.
- Manitoba
I heard one the Dutch forum members is about to try to create one from the one side that is still available. Maybe he can jump in here as well?
- mcjjordan
- My E21(s): Uk 1980 316 m52
I had to buy 2 same side & cut them up & weld to make a mirror version of the one you can get.
Munich icons use 5 series i think .
bealo
- My E21(s): 83 316 1.8
82 320/6 - Location: Essex
I’ve been in contact with Munich icons but they couldn’t help
