Where to find this part
adams02
Post by adams02 »
I have a 2002 that was swapped with a 320i M10. I'm in the process of replacing the wiring harness and got everything but the distributor. I don't have the original harness and can't find the connector online. Any idea where I can find the distributor wire connector?
Here's a picture:
https://www.google.com/url?sa=i&url=htt ... AdAAAAABAD
Re: Where to find this part
You mean the connector for the pulse sender? Facelift model? Perhaps cut it off a wrecker and solder it onto your own wiring loom? I believe many M10 engines use the same connector.
adams02
Post by adams02 »
Yes, not sure if its a facelift. I've been on the lookout for junkyard M10s near me but no luck.
