Fan blower
bealo
My E21(s): 83 316 1.8
82 320/6
Fan blower
Post by bealo »
Need some help…
My fan blower isn’t working
The fuse and relay are both tested and working
I’ve put power directly to the motor and this is working
I’ve put power to the fuse holder and it works with the switch on all speeds
Lastly I tried another fuse box in case the metal track was damaged but still no good.
Also the re screen de mist isn’t working but will work with power to the fuse holder.
Is this some kind of ignition issue?
nic65
Re: Fan blower
Post by nic65 »
it happened to me too when I reassembled the car, it was a problem in the fuse and relay box
bealo
82 320/6
Re: Fan blower
Post by bealo »
What exactly was the problem?
nic65
Re: Fan blower
Post by nic65 »
a bad contact in the connections inside the box, you must turn it upside down, remove the cover and clean the contacts
