My alpina b6 2.8 looking for ecu
Dear seniors, I live in Japan and have a 1981 E21 B6 2.8. However, the B6 2.8 does not have an ECU and does not work. Can someone tell me the part number for the B6 2.8 or a replacement part?
Re: My alpina b6 2.8 looking for ecu
You would have to trace the BMW model that used that engine and I could trace the DME code
Thank you for your reply. The engine code is M30B28 L-jetronic.
It could be a Bosch Ljet 0280001108 used on 528-628-728-733
There is a specific Alpina part number for the Bosch L-Jet M30 DME with Alpina mapping, Alpina P/N 12 10 116. It may be costly, but there is a chance that Alpina can still supply it.
Thank you all. Thanks to you all, one day my Alpina will be able to run.
