When I short circuit all 3 wires of the TPS, the engines's idle go up... 1200-1300 rpm....
i've screwed clockwise the master idle screw between 3° and 4° cyl but engine's rpm are 1100...1200.. (the tps is disconnetted and short-circuited)
I've a doubt!
i must adjust the idle 880 +- 50 rpm by adjust the 4 screw with vacuometer (300 +- 50 mbar) (tps disconnected) ? or
only adjust the vaccum (at for example 270mbar) and adjust the idle with master screw at 880 --50 with tps connected?
it's normal that the engine's idle go up?
Thenk you!
