**Locating the Flasher Relay**
MRE21
My E21(s): Audi RSQ3 8U (Previously owned E21 320
Post by MRE21 »
Hi Guys,
Has anyone changed their flasher relay? Where is it? and where can I get a replacement? (GSF said they did not supply them anymore?)
Thanks
Ali
:D
1980 BMW 320/6 OEM (Now sold😥)
2014 Audi RSQ3 8U
drjim
Post by drjim »
It's inside the steering column shroud as I recall, undo the two screws holding the bottom bit on and it should be there. Fairly standard relay, any motor factors should have one, or try euro car parts.
Jim
1982 Saphirblau Baur 325i
Cars all gone!
MRE21
Post by MRE21 »
Thanks m8 I will have a look...
2014 Audi RSQ3 8U
clarkandrew45
Re: **Locating the Flasher Relay**
Post by clarkandrew45 »
How much would shops cost me if I have them replaced my flasher relay? I've seen from this relay list that it would be cheaper if I replace it myself since a relay cost less than $20.. problem is the level of difficulty of the DIY..
MRE21
Post by MRE21 »
clarkandrew45 wrote:How much would shops cost me if I have them replaced my flasher relay? I've seen from this relay list that it would be cheaper if I replace it myself since a relay cost less than $20.. problem is the level of difficulty of the DIY..
I would buy the relay switch and fit it yourself. I should have taken pictures for people to see, but it really is easy! All you need is a star screwdriver (large) and unscrew 4 screws underneath the steering column. They are quite long so be patient! Once you have removed the screws, unclip the plastic cover and you will see the black relay switch- Just unclip and replace with new. It should take you about ten minutes! I thought it would be difficult but it was quite straight forward. Good luck :playcar
2014 Audi RSQ3 8U
