Dellorto Idle Screw stuck..
Reck
Post by Reck »
One of the brass idle screws on my dellortos won't move - Anyone have any advice to get it shifted or will I have to have it drilled out?
Cheers
Jason
Re: Dellorto Idle Screw stuck..
You might have to remove the carb and get it in a vice? You'll be able to get it level and soak the thread with WD40 or maybe play a bit of gentle heat on there using a hot-air gun? Drilling shouldn't be needed.
Reck
Post by Reck »
Cheers mark. I'll keep blasting it with WD40 as I cba taking them off!
Reck
Post by Reck »
As an aside I'm getting 18MPG. I knew they'd be thirsty, but not that thirsty!! e_surprised
Seriously considering going back to the Weber but the noise these dellortos make is incredible.
If you know how good they sound you can't have been driving with good MPG in mind! :)
