One of the brass idle screws on my dellortos won't move - Anyone have any advice to get it shifted or will I have to have it drilled out?
Cheers
Jason
Dellorto Idle Screw stuck..
- e21-Mark
- E21 Master
Re: Dellorto Idle Screw stuck..
You might have to remove the carb and get it in a vice? You'll be able to get it level and soak the thread with WD40 or maybe play a bit of gentle heat on there using a hot-air gun? Drilling shouldn't be needed.
Reck
Cheers mark. I'll keep blasting it with WD40 as I cba taking them off!
Reck
As an aside I'm getting 18MPG. I knew they'd be thirsty, but not that thirsty!!
Seriously considering going back to the Weber but the noise these dellortos make is incredible.
- e21-Mark
- E21 Master
If you know how good they sound you can't have been driving with good MPG in mind!
