cobbler2u
Posts: 843 Joined: Fri Apr 17, 2009 8:17 pm
My E21(s): 323i baur 323i special 328 sport 325i
Post
by cobbler2u » Wed Aug 15, 2012 9:42 am
Temp needle goes onto red.
The problem is that the car is not overheating. Changed temp switch and clocks.
Still same problem.
Need to fix before gaydon
cobbler2u on Wed Aug 15, 2012 10:43 pm, edited 2 times in total.
Posts: 30217 Joined: Tue Sep 14, 2004 12:23 pm
Post
by Jeroen » Wed Aug 15, 2012 10:04 am
Usually its the sender. Did you check if the thermostat opens?
cobbler2u
Post
by cobbler2u » Wed Aug 15, 2012 10:46 pm
Tried still all the same.
The gauge is all over the place . It sways all over the place
Post
by Jeroen » Wed Aug 15, 2012 10:53 pm
Well in that case at least ur sure its an electrical issue... wiring loom issue if you replaced the sender at the start and the gauge at the end
Danny043
Posts: 758 Joined: Tue May 15, 2007 4:16 pm
Post
by Danny043 » Sat Aug 18, 2012 10:29 pm
I had this problem too, temp needle dancing all over the place. Turned out the earth cable ( - cable) to the battery came loose and just needed to be tightened again. Hope yours is just as easy to fix
1979
320i Antrazitgrau US spec
cobbler2u
Post
by cobbler2u » Sun Aug 19, 2012 12:09 am
Got it fixed I hope
Turn out to be bad / old wiring
cobbler2u
Post
by cobbler2u » Sun Aug 19, 2012 12:15 am
Seems when ever Gaydon comes around the car seem to get very temperamental on me
Post
by Jeroen » Sun Aug 19, 2012 11:18 am
cobbler2u
Post
by cobbler2u » Mon Aug 20, 2012 9:29 am
Was a good run to gaydon.
Car run with no problems.
