high temp
cobbler2u
My E21(s): 323i baur
323i special
328 sport
325i
high temp
Post by cobbler2u »
Temp needle goes onto red.
The problem is that the car is not overheating. Changed temp switch and clocks.
Still same problem.
Need to fix before gaydon :hammer
Re: high temp
Usually its the sender. Did you check if the thermostat opens?
cobbler2u
323i special
328 sport
325i
Re: high temp
Post by cobbler2u »
Tried still all the same.
The gauge is all over the place . It sways all over the place
Re: high temp
Well in that case at least ur sure its an electrical issue... wiring loom issue if you replaced the sender at the start and the gauge at the end
Danny043
Re: high temp
Post by Danny043 »
I had this problem too, temp needle dancing all over the place. Turned out the earth cable ( - cable) to the battery came loose and just needed to be tightened again. Hope yours is just as easy to fix :smoke
cobbler2u
323i special
328 sport
325i
Re: high temp
Post by cobbler2u »
Got it fixed I hope
Turn out to be bad / old wiring
harleytrike
Re: high temp
Post by harleytrike »
sorted :)
cobbler2u
323i special
328 sport
325i
Re: high temp
Post by cobbler2u »
Seems when ever Gaydon comes around the car seem to get very temperamental on me
Re: high temp
:thumbsup
cobbler2u
323i special
328 sport
325i
Re: high temp
Post by cobbler2u »
Was a good run to gaydon.
Car run with no problems.
