Pandemoniums 316 restore
pandemonium001
- My E21(s): E12 535i T (ish)
Re: Pandemoniums 316 restore
good thread on building a performance head
http://www.nicoclub.com/archives/how-to ... -head.html
pandemonium001
Not much new to show but started the same the other side.
removed the repair panel and it was in better condition than the other side
Im getting faster at this only took and hour to get to this stage.
Are you using a spit there?
- e21-Mark
Thanks for all the updates Martin. Keep them coming.
pandemonium001
No, but i will be making one when the boot goes back in for blasting and paint,nas80 wrote:Are you using a spit there?
pandemonium001
pandemonium001
still welding.
fuel filler pipe support.
I am thinking i may stitch weld up the chassis rails there is a little bit of movement and a slight gap after i stripped some of the underseal
think I may also cut out and replace with straight metal.
started cutting out floor pan patches.
another improvised effort.
then ran out of argoshield, so more stripping done.
list is down to about 6 jobs on the shell now.
but still many many many hours of grinding left yet.
Well you've come a long way already, nice progress!
One of my favourite topics.
pandemonium001
Thanks, I'm still trying to catch up with the rest of the builds.pic wrote:One of my favourite topics.
next big cost will be the grit blasting, if i Hire DIY it will be about £400 including 1Ton of crushed glass.
so if i can get a mobile guy for less i will go for that.
you'll be able to eat your dinner off the underneath of that car.
pandemonium001
I Hope so, got another half bottle of argoshield now and new 0.8mm tips, tapered shields, just need another bit for my euro torch as well and im back on track.nas80 wrote:you'll be able to eat your dinner off the underneath of that car.
got another bargain as well, a Bullfinch auto torchbrazing kit, at BOC on the shelf reduced from £138 to £18, quized a bit to see if it can actually get hot enough to braze the rear panel? lists 950C to optimum conditions 1200C. said i would take it and try, he then gave it to me for free!!!! RESULT.
pandemonium001
More cleaning grinding and welding.
before
after
easy way to copy hard to measure shapes. lay a rag over it then spray paint from other side and transfere
Getting there,
On another note, got a quote for blasting the shell. £200 for under side engine bay and boot. will get the whole car done appart from roof and rear Qtr's
before
after
Getting there,
Nice job! Again.
Your welding is very tidy. Nice work btw.
So which engine are you going to use?
