Bodyshell.
I am at the point where I have a non-sunroof shell that has been stripped of all the sound deadening material, seam welded and a welded cage fitted c/w door bars & twin diagonals. It also has poly windows and fiberglass bonnet, boot & wings. I have also removed the boot floor and rear bulkhead, which was replaced with sheet aluminium. What else can be done to lighten the shell, other than chopping out the door internals?
Should the cage be tied into the front and rear suspension turrets? Should I use gussets between A & B pillars and cage?
Suspension
I am running GAZ golds & adjustable front top mounts, combined with front and rear strut braces. In the past I have used 600lb front springs and 275lb rears but still suffer understeer on some faster corners. (in particular Clearways at Brands Hatch where I was destroying front n/side tyres) What is a good baseline geo to start with? What are the benefits / negatives between running with 15'' rims over 13'' and vice versa?
Seat mounting
I would like to mount my seat as low as possible but obviously an e21 floor isn't just flat. Is the easiest / best way to weld a pair of bars between the inner sill and transmission tunnel and bolt the seat to that? Can I alter the angle of the steering column to bring the steering wheel a little lower?
I think that's enough for now. I'm sure there will be other questions as things progress.
If anyone else, who has a competition e21, can post phots from their builds it would be good to see them please.
