Pandemoniums 316 restore
- My E21(s): E12 535i T (ish)
Re: Pandemoniums 316 restore
I also plan to run a length of 2.5mm wall thickness 1"x1 1/2" box down the length of the car tucked behind the spot welded flange on the sill, seam weld that in, then triangulate front and rear subframes to that. it will also provide a nice jacking point both sides.
It sounds like you will have plenty stiffness. That wing reinforcing bar can be fitted but it does look like itd get in the way. However that front wing is held on by sooo many bolts i dont think theres a problem if its missing a few..
- Mihajlo
- My E21(s): 1982 315swap323i
Did you examine welds for cracks?
Nice work you're doing there! I like!
Do you mean mine or factory ones?? both? either way good idea I will get some FPI fluid and do an inspection before paint.
THB some of the weld's could do with tidying up, I am just starting to get a bit impatient to get to the good bit, paint and building.
- Mihajlo
I meant your welds...pandemonium001 wrote:Do you mean mine or factory ones?? both? either way good idea I will get some FPI fluid and do an inspection before paint.
1" welds are more likely to crack than spot welds which are factory ones....
It's not bad to weld fiew welds and then start welding on the other side of the car to allow to cool previous welds...
Turning here into an electric car is why you don't need the fuel filler anymore?
you having a fuel cell in the boot? great idea that tbh.
- Jason_323i
I ran a fuel cell in the Boot on my e21 and m3, pain in the ass at petrol stations as they won't let you fill up as they think you are filling milk bottles with petrol (or mabey that's just me). I gad to quite often go explain my petrol filler was in the boot.
before they would switch the pump on.
Jason
PS top work as always and where are you on the west cost
Jason
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
Z3M Coupe
2.8 Z3 Coupe
Caterham Supersport
I plan on keeping the OEM tanks, although 1 may be scalloped out/deleted depending on the side exit exhaust.
if range is ever a problem LPG in the wheel well is always an option.
I like how clean this BMW looks with the swage line and want to have that both sides.
taking some insparation from here as well
see where the fuel filler is! in the bonnet. I could do that on the boot somewhere? I am still thinking on a hinged rear light cluster with the filler behind it, or possibly behind the black middle panel between the lights.
5 miles outside Prestwick, 30miles south of glasgowJason_323i wrote: PS top work as always and where are you on the west cost
- Mihajlo
Ou yeah! Singer is my wet dream!
- e21-Mark
I've been looking at Singer and others myself. I was looking at how to bring a little body colour inside the car? (apart from the rear cage) I have one thing in mind but don't want it to look too much. I opted for the Prototipo wheel too. Gotta love what they've done with the seats.
+1 for the prototipo for mine. im going to delete the fuel filler flap too when it gets to bodywork time I fancy an E9 style drop down rear panel filler on mine. are you thinking colours yet?
