Re: Uwbuurman: 1978 323i polaris: Sticky business!
uwbuurman wrote:Thanks for your very kind words, Walter! Looking forward on drinking a beer with you in september!
Bert, yes, clean it with a strong degreaser and paint it.
Same here, Koos. Can't wait 'til it's the end of September... :launch :cheers
That's going to be one quiet E21!
The inside is covered with the damping material. After that I got the frame from under the car, so I could sand and paint the contactsurface with the frame.
After tha, I prepared the car for spray on anti stonechip undercoating. I used Dinitrol 448, which is waterbased. Started with wrapping the car.
Rear side was a bit tricky, because i didn’t know where to put the tape. Where does the seam go? I took measures from some very original cars, but BMW’s did a poor job, none where the same. I even found one car with two very different sizes of the stonechipcoating.
I put the tape on 50mm from the panelseam.
Then I build me a nice paintbooth :bag
The result is very satisfying.
Re: Uwbuurman: 1978 323i polaris: Spray tan!
Since the body is ready fort he painter, I started working on the other parts that need paint.
The bonnet has some samll dents and minor rust on the known places near the air vent.
The bootlid, seems to be in a good nick. But the holes for the typeplate are not how I want them. Not straight and a wornout hole.
A closer look shows a strange round shape.
A push and we have an extra hole. This stupid car never seizes to amaze me…
Another hole looks like two holes joined.
Sanded it and found some rust around the holes. So I cleared the rust and welded the holes shut.
Nuts and bolts from under the bonnet, front wings and bootlid and some other stuff that needs to be painted.
Boothlid with torsionbars and bonnetbar.
My fresh sandblasted and primered front valance and boothinges
When all was done, the car was ready for transportation to the painter.
At the painter who welded the roof back in 2012.
Now the car is gone for paint, I have some time for other chores. I went on with my popout windows, for which I bought those Chinese screws. But those screws were too long, so I cut them off. The head of the screw is slightly too thick for the lower moulding, so I grinded it down, because I didn't want them to scratch the lower moulding. After that I had the screws zincplated.
Two normal and two grinded heads.
Besides the screws, I need some ribbets to put it all together. I found these blind rivets, 5mm long and 3mm thick. Perfect fit.
And put it together.
Mouldings, rubber and glass.
And this is what a brand new pop out window looks like. New mouldings (NLA), new rubbers (freakin’expensive), new glass (long, long wait)
To put the glass in the rubber and that in the mouldings, you need some lubricant. I used Dinitrol, which preserves the mouldings and metal connection angles. I ordered those angles at BMW’s. The upper one, 90 degrees, is NLA. So they send me the 60 degrees one, double. But as I tried tob end it to use it fort he upper corner, it didn’t fit. All three angles are only usable fort he corner that theay are meant for. The holes don’t line up on the other corners.
Smartie
My E21(s): 320/6 '78 rip
323i '78 wip
Post by Smartie »
Job well done! +200%
crazyarms1956
My E21(s): 78´323i
Post by crazyarms1956 »
Perfect work !!!
Speed is nothing without control
BuschBertl
My E21(s): 323i S-Edition E21, 325i E30, M3 E46
Post by BuschBertl »
Very nice. I love the way you work. :shock:
BB-Carworks
BMW E21 323i S-Edition 1982
BMW E30 325i Cabrio 1991
BMW F87N M2 Competition 2018
Thanks! comming from you, with the way you work, it is a huge compliment.
pandemonium001
My E21(s): E12 535i T (ish)
Post by pandemonium001 »
super work. :thumbsup
Thanks mate!!!!
looking for a new page
and
of to page 29!!
And we started on the paint job!! At first we started to prepare al the loose parts, starting with the bonnet and trunklid.
The bonnet was the best of two I have, but still some spots, lots of dirt and a rotten ledge.
This much dirt came off…
This ledge is repaired, here before grinding and sanding.
