my 316 m52 swap
Gavin Martin
- My E21(s): '81 316 - '80 320/6
Re: my 316 m52 swap
Thanks fellas
still a mountain of jobs to do and my January deadline has gone right out the window
Gavin Martin
Re: my 316 m52 swap
Brake kit now ordered also, these were the best value off the shelf kit I could find, and quite reasonably priced at £680 from corby motor sport. 296mm x 22mm with four pot calipers
Gavin Martin
Re: my 316 m52 swap
Making the most of my paternity leave
getting the odd 30-45 minute sessions in the garage. Cleaning and finding the bits are taking time but it's coming together. Going to need new headlights, as these have gone cloudy. Any suggestions on the best place to get these?
Gavin Martin
Re: my 316 m52 swap
Nice 'n clean! Before throwing them out you can try washing the headlights. Some washing liquid and hot water, and a blowdryer after.
Gavin Martin
Re: my 316 m52 swap
Thanks jeroen
I hadnt thought of that, i will give that a go.
I was thinking of using a surgical/alcohol solution or something similar?
Re: my 316 m52 swap
Well I did this a couple of times before and used washing up liquid, just a little bit, to get rid of the greasy mist. Add hot water and a good shake and it cleans up quite ok.
Moutinho
- My E21(s): ´79 Euro 320/6 5speed Manual
Re: my 316 m52 swap
is that brake kit a plug and play option? that front end is just gorgeous, so clean!
Gavin Martin
Re: my 316 m52 swap
ThanksMoutinho wrote:is that brake kit a plug and play option? that front end is just gorgeous, so clean!
Gavin Martin
Re: my 316 m52 swap
Got some bits back from the powder coaters today so managed to get some more done
Gavin Martin
Gavin Martin
