Oil additives? Any experience/opinion
- petroscf
Has anyone any experience with oil additives?
Are there any good ones? or a waste of money?
Does anyone know this one? http://www.abro.com/ot-511.html
/oo=00=oo\
E21 Forever
E21 Forever
Re: Oil additives? Any experience/opinion
No experience but why would you consider an oil additive .. i d rather use good oil like mobil extended life and change it every 5000 km.
In my opinion oil additives are a waste of time ..
My thoughts exactly and moreover, a total waste of money
- petroscf
Yes, generally I won't disagree, I was just wondering: why some known manufacturers do keep such products in their catalogues then? If they are already mixing these in their oils, what's the reason to sell the additives separately?
/oo=00=oo\
E21 Forever
E21 Forever
For the same reasons businesses sell spark plug sparks
always someone who buys them
- petroscf
??? I don't think I understood...what is this blue dust exactly supposed to do??
/oo=00=oo\
E21 Forever
E21 Forever
Engine oil additives I wouldn't bother with but I have had good experience of manual transmission additives. When I say good they have quietened down and extended the life of a worn manual transmission, OK it's a bodge but I've found it worth while!
- petroscf
A bit of a late reply here, but can you suggest a good additive for lsd maybe? This is what I need to quieten down on my car...e21Keith wrote:Engine oil additives I wouldn't bother with but I have had good experience of manual transmission additives. When I say good they have quietened down and extended the life of a worn manual transmission, OK it's a bodge but I've found it worth while!
/oo=00=oo\
E21 Forever
E21 Forever
If a good oil change fo the ricgt spec oil for your lsd doesnt help, then it is worn. But mind you, lsd's tend to be noisier then open diffs.
- petroscf
It's good to know that some noise from an lds might be normal because my noise is not that much. I would however like to have an idea of the kind/type or even "quantity" of noise that an lsd is normal to produce... My diff is heard a bit like a car on reverse gear if I want to describe the noise.uwbuurman wrote:If a good oil change fo the ricgt spec oil for your lsd doesnt help, then it is worn. But mind you, lsd's tend to be noisier then open diffs.
/oo=00=oo\
E21 Forever
E21 Forever
- Mihajlo
- My E21(s): 1982 315swap323i
Change bushings on the diff (that helps a lot).
Put some sound isolation in the car.
Swap your LSD unit to less worn out case where ring and pinion are in a good shape.
and change LSD oil every 10000km (or less)
- petroscf
Well, ring and pinion seem to be ok, of course I guess the eye can't tell in such cases...Mihajlo wrote:Change bushings on the diff (that helps a lot).
Sound isolation you mean should be put to the back? for example behind and under rear seat? (for diff noise isolation) ?
/oo=00=oo\
E21 Forever
E21 Forever
