Oil additives? Any experience/opinion
petroscf
My E21(s): '77 EU 316 manual
Post by petroscf »
Has anyone any experience with oil additives?
Are there any good ones? or a waste of money?
Does anyone know this one? http://www.abro.com/ot-511.html
/oo=00=oo\
E21 Forever
Re: Oil additives? Any experience/opinion
No experience but why would you consider an oil additive .. i d rather use good oil like mobil extended life and change it every 5000 km.
In my opinion oil additives are a waste of time ..
My thoughts exactly and moreover, a total waste of money
petroscf
Post by petroscf »
Yes, generally I won't disagree, I was just wondering: why some known manufacturers do keep such products in their catalogues then? If they are already mixing these in their oils, what's the reason to sell the additives separately?
/oo=00=oo\
E21 Forever
For the same reasons businesses sell spark plug sparks
always someone who buys them
petroscf
Post by petroscf »
???? What is this???
/oo=00=oo\
E21 Forever
Sparks, for your sparkplugs!!!
petroscf
Post by petroscf »
??? I don't think I understood...what is this blue dust exactly supposed to do??
/oo=00=oo\
E21 Forever
It is a practical joke. Sprakplug sparks.....
e21Keith
My E21(s): '81 323i Manual
Post by e21Keith »
Engine oil additives I wouldn't bother with but I have had good experience of manual transmission additives. When I say good they have quietened down and extended the life of a worn manual transmission, OK it's a bodge but I've found it worth while!
petroscf
Post by petroscf »
e21Keith wrote:Engine oil additives I wouldn't bother with but I have had good experience of manual transmission additives. When I say good they have quietened down and extended the life of a worn manual transmission, OK it's a bodge but I've found it worth while!
A bit of a late reply here, but can you suggest a good additive for lsd maybe? This is what I need to quieten down on my car...
/oo=00=oo\
E21 Forever
If a good oil change fo the ricgt spec oil for your lsd doesnt help, then it is worn. But mind you, lsd's tend to be noisier then open diffs.
petroscf
Post by petroscf »
uwbuurman wrote:If a good oil change fo the ricgt spec oil for your lsd doesnt help, then it is worn. But mind you, lsd's tend to be noisier then open diffs.
It's good to know that some noise from an lds might be normal because my noise is not that much. I would however like to have an idea of the kind/type or even "quantity" of noise that an lsd is normal to produce... My diff is heard a bit like a car on reverse gear if I want to describe the noise.
/oo=00=oo\
E21 Forever
Mihajlo
My E21(s): 1982 315swap323i
Post by Mihajlo »
Change bushings on the diff (that helps a lot).
Put some sound isolation in the car.
Swap your LSD unit to less worn out case where ring and pinion are in a good shape.
and change LSD oil every 10000km (or less)
petroscf
Post by petroscf »
Mihajlo wrote:Change bushings on the diff (that helps a lot).
Well, ring and pinion seem to be ok, of course I guess the eye can't tell in such cases...
Sound isolation you mean should be put to the back? for example behind and under rear seat? (for diff noise isolation) ?
/oo=00=oo\
E21 Forever
