Either its the heat or something, but Im confused ! My brake pedal travels too far. Im sure the rod from the pedal needs to be adjusted. Am I right in thinking I should shorten it ?
Thanks, Neil
Brake rod adjustment
healeyneil
- My E21(s): '81 318is Baur - ahead of its time !
Re: Brake rod adjustment
It doesn't just go out of adjustment because of the weather. How much further do you need to push the pedal?
Or are you low on pressure due to a leak, or air in the system?
healeyneil
It's always been bad ! The reference to the heat was the effect on my brain !
The brake pedal has always had a longer travel than I'd like. I've lived with it too long is all
healeyneil
Just to update, shortening the rod does reduce pedal travel. Much better now
