Brake rod adjustment
healeyneil
Post by healeyneil »
Either its the heat or something, but Im confused ! My brake pedal travels too far. Im sure the rod from the pedal needs to be adjusted. Am I right in thinking I should shorten it ?
Thanks, Neil
e21Keith
My E21(s): '81 323i Manual
Re: Brake rod adjustment
Post by e21Keith »
It doesn't just go out of adjustment because of the weather. How much further do you need to push the pedal?
Or are you low on pressure due to a leak, or air in the system?
healeyneil
It's always been bad ! The reference to the heat was the effect on my brain !
The brake pedal has always had a longer travel than I'd like. I've lived with it too long is all
healeyneil
Just to update, shortening the rod does reduce pedal travel. Much better now
:thumbsup
