Mechanical Fuel Pump
20cent
My E21(s): '80 316 1.8 manual
Post by 20cent »
Hi everyone
I recently bought a 1980 E21 316 with the 1766 cc engine. It seems to be having a problem with the mechanical fuel pump, when it is driven by the engine it doesn't seem to be pumping anything but when I remove it and operate it manually it seems to work just fine. When turning over the engine without the fuel pump I can see the rod that is supposed to push the spring in the pump move a little. Does this mean the cam is worn and I have to replace the camshaft or is there another solution?
shadyracer01
My E21(s): 323i '82 Y x2, 1 in resto, 1 now spares
Re: Mechanical Fuel Pump
Post by shadyracer01 »
If theres a separate pushrod between pump and camlobe then maybe a longer pushrod or modification can be effected. If also theres a thick mounting gasket for pump housing to cambox then perhaps this can be slimmed down a bit, wear on camshaft unlikely id say but not impossible.
Believe I've heard of these issues before and then a thinner (skimmed) gasket might indeed help getting enough movement of the pushrod, but I think I'd try a different fuel pump first.
20cent
Post by 20cent »
Thanks for the replies, I will try this.
Great! And if you could find the time to introduce the car to us, it would be great. Lots of pics please :mrgreen:
Stefke
My E21(s): E21 320
Post by Stefke »
Anny tips on how to remove the fuelpump mounted on the enginge? I cant reach the bolts to reove the pump.
Which engine? Picture perhaps? Regular fuel pump of the carbureted versions is easy to reach with a spanner, but perhaps your engine received a new aftermarket pump?
