Hi everyone
I recently bought a 1980 E21 316 with the 1766 cc engine. It seems to be having a problem with the mechanical fuel pump, when it is driven by the engine it doesn't seem to be pumping anything but when I remove it and operate it manually it seems to work just fine. When turning over the engine without the fuel pump I can see the rod that is supposed to push the spring in the pump move a little. Does this mean the cam is worn and I have to replace the camshaft or is there another solution?
Mechanical Fuel Pump
shadyracer01
- My E21(s): 323i '82 Y x2, 1 in resto, 1 now spares
Re: Mechanical Fuel Pump
If theres a separate pushrod between pump and camlobe then maybe a longer pushrod or modification can be effected. If also theres a thick mounting gasket for pump housing to cambox then perhaps this can be slimmed down a bit, wear on camshaft unlikely id say but not impossible.
Believe I've heard of these issues before and then a thinner (skimmed) gasket might indeed help getting enough movement of the pushrod, but I think I'd try a different fuel pump first.
Thanks for the replies, I will try this.
Great! And if you could find the time to introduce the car to us, it would be great. Lots of pics please
Anny tips on how to remove the fuelpump mounted on the enginge? I cant reach the bolts to reove the pump.
Which engine? Picture perhaps? Regular fuel pump of the carbureted versions is easy to reach with a spanner, but perhaps your engine received a new aftermarket pump?
