Kolbenschmidt Pistons
I have been offered a set of Kolbenschmidt E21 323i pistons for sale.
Are these any good?
Regards,
Yatis
Are these any good?
Regards,
Yatis
Re: Kolbenschmidt Pistons
Thank you for the information. (My apologies for not thanking you sooner). It turns out that this set of pistons may not be for an E21 323i because the part number does not match the E21 323 piston number in the Kolbenschmidt classic parts catalogue.
Walloth & Nesch has a set of oversize pistons (+0.5) for sale. But looking at the pictures of these pistons (see link below), their size is 80.468mm, whereas the correct size (if I am not mistaken) is 80.48mm. Also the Walloth &Nesch part number does not seem to correspond with the equivalent part number in the BMW online catalogue.
https://www.wallothnesch.com/en/set-of- ... 21-01.html
Does anyone know what these Walloth & Nesch pistons are?
Regards,
Yatis
Regards,
Yatis
Thank you for this information. The problem is that I won't need the new pistons for an another three years, when my car will be expected to undergo an engine rebuild at 440,000km, which is also the time the next timing belt change is scheduled (the last rebuild was at 204,000 km). The mileage now is 411,000 km. I think that, after consulting my long suffering mechanic (who is excellent but tells me he will die if he has to look after another old car), I should wait until the engine is opened up for a rebuild before deciding on a piston solution. Hopefully, I will still have piston options then.
Yatis
Yatis
I would suggest just buying them and have them laying around when needed. Parts like that never depreciate in value.
Oversize pistons for these engines are very difficult to find, 5 years ago when I needed a set I could only find new ones from Ireland Engineering, but their lead time was too long for me
The original set of Kolbenschmidt pistons I was offered was not for the E21.
I have now been offered a set of 6 +0.50 Kolbenschmidt pistons with the individual part number 93 540 630. My research suggests that this is the correct piston for the BMW E21 323i with the standard 200 head. Would I be correct?
Thanks in advance.
Yatis
Thanks in advance.
Yatis
Will the 1125 1 284 998 piston for the E30 323i work with the E21 323i's 200 head?
Thanks in advance for any advice on my query.
Yatis
Yatis
Just to clarify my preceding post: 1125 1 284 998 is the BMW part number for the +0.50 piston for the e30 323i (not a Kolbenschmidt number). Will this fit the 200 head on the E21 323i? My research on past posts on this site suggests that it will but will result in slightly higher compression because the e30 pistons are slightly domed whereas the E21 pistons for the 323i are flat. Am I correct?
Thanks.
Yatis
Thanks.
Yatis
