I have been offered a set of Kolbenschmidt E21 323i pistons for sale.
Are these any good?
Regards,
Yatis
Kolbenschmidt Pistons
Re: Kolbenschmidt Pistons
Thank you for the information. (My apologies for not thanking you sooner). It turns out that this set of pistons may not be for an E21 323i because the part number does not match the E21 323 piston number in the Kolbenschmidt classic parts catalogue.
Walloth & Nesch has a set of oversize pistons (+0.5) for sale. But looking at the pictures of these pistons (see link below), their size is 80.468mm, whereas the correct size (if I am not mistaken) is 80.48mm. Also the Walloth &Nesch part number does not seem to correspond with the equivalent part number in the BMW online catalogue.
https://www.wallothnesch.com/en/set-of- ... 21-01.html
Does anyone know what these Walloth & Nesch pistons are?
Regards,
Yatis
Regards,
Yatis
Thank you for this information. The problem is that I won't need the new pistons for an another three years, when my car will be expected to undergo an engine rebuild at 440,000km, which is also the time the next timing belt change is scheduled (the last rebuild was at 204,000 km). The mileage now is 411,000 km. I think that, after consulting my long suffering mechanic (who is excellent but tells me he will die if he has to look after another old car), I should wait until the engine is opened up for a rebuild before deciding on a piston solution. Hopefully, I will still have piston options then.
Yatis
Yatis
I would suggest just buying them and have them laying around when needed. Parts like that never depreciate in value.
Oversize pistons for these engines are very difficult to find, 5 years ago when I needed a set I could only find new ones from Ireland Engineering, but their lead time was too long for me
