Rob and Joost E12 528 type 1 ----> 535i
RobK
- My E21(s): bmw e12 type1 535i replica
Re: Rob and Joost E12 528 type 1 ----> 535i
Or a sharknose meeting without e9, e3, 2002, e21,e24,e23 and e28...
Yoozt
- My E21(s): Non E21: E28 525E, E12 535i
we're ready with the next step, not finished yet, but we're getting there:
We painted the engine bay (finally, what a pain that was) and the trunk.
Plus we put filler on the doorsteps + wheel arches + new exhaust cutout
So now we only need to do the outside of the car: so sanding, maybe some filling and then the final paint! until then, he're some pics
fresh primer:
and then the filler goes on
first layer:
and second layer, back is not perfect, but we'll see if we're going to fix it
this side is perfect
this side needs some work (sanding)
aaand its finished
looks dark, but thats because the photos are made with a phone.
we used the 'wet on wet' technique. Normally you spray the filler on it and after its dry you sand it first before you spray the paint on.
Now we used thinner filler + we sprayed the car right after. This saved us a lot of time, because we didnt have to sand the engine bay again (pfew)
Next update will be about finishing the car....finally!
fresh primer:
first layer:
aaand its finished
Nice progress! Looking forward to see some detailed results on applying the wet on wet principle as this may be a brilliant solution for tough spots like the engine bay indeed!
When do you buy an e12!
Yoozt
@ jeroen: I will make some pictures when we are back at the car, while it was still wet it looked great! The idea is to us thinner filler so it becomes more smooth than normal. so 2 layers filler (first just a thin layer so the second layer can hold better) and then the same with the paint an the clearcoat, so 6 layers in total. And just let it dry for a couple of minutes (when the shine is off).
@ 323baur, what do you mean? or is it adressed to Jeroen?
here some more picks, while still wet:
Yup, i ment indeed jeroen.
Btw,massive big steps are being made!
To bad this one is RHD...323baur wrote:Yup, i ment indeed jeroen.
http://www.munichlegends.co.uk/componen ... ew,detail/
It has been full restored by TONY
http://retrorides.proboards.com/thread/88328?page=1
Very nice work you have achieved.
Yoozt
wow, great project! thanks for the linkbmw e12 e21 wrote:To bad this one is RHD...323baur wrote:Yup, i ment indeed jeroen.
pandemonium001
- My E21(s): E12 535i T (ish)
Top work there
. Colour looks great, I can never get enough time in one go to go wet on wet in the garage, always end up spending ages panel wiping and setting up the following weekend.
Which products do you use? Upol? how much do you thin the high build primer by? 20%
Nice work. I can't wait to see more building pictures.
Nice work .. can't wait for upgrades
Topjob!
Nice to see a w124 for whats it worth for...work.
RobK
haha yes indeed... Taxi or carrying a nice E12
- Peter E12 525
It looks really nice! can't wait to see the finished result.
